#294479 - 01/03/2007 18:29 "there isn't a fid 2 on this device"
julf
I am using mp3tofid and rsync to keep my empeg and my main mp3 server in sync, together with jemplode. But every time I sync, I get the error message "there isn't a fid 2 on this device" from jemplode. Does fid 2 have any magical special significance?
#294480 - 01/03/2007 20:53 Re: "there isn't a fid 2 on this device" [Re: julf]
pim
You can't really mix mp3tofid and (j)emplode.
If you use (j)emplode and switch to mp3tofid+rsync, all your music will be reloaded.
If you use mp3tofid+rsync and the switch back to (j)emplode, you should be able to change things manually again. But if you then use mp3tofid+rsync again, it will undo all those manual changes made by (j)emplode.
Pim
#294481 - 01/03/2007 23:36 Re: "there isn't a fid 2 on this device" [Re: julf]
pim
mp3tofid writes a fake fid #0 of type "illegal", creates the root playlist at fid #100 and then starts allocating starting at fid #120. I based this on inspection of the database, the free empeg sources and on developer information.
I never came across fids 1-99. But then I never have used jemplode.
Pim
#294482 - 02/03/2007 04:56 Re: "there isn't a fid 2 on this device" [Re: pim]
julf
Well, you can, if you are really, really careful
I don't actually use jemplode to upload any music - only to check on things.
#294483 - 02/03/2007 06:02 Re: "there isn't a fid 2 on this device" [Re: pim]
Fids < 0x100 are reserved, as is 0x110. See the emptool source code for details.
#294484 - 03/03/2007 23:01 Re: "there isn't a fid 2 on this device" [Re: julf]
dr_dos
Loc: Bendorf, Germany
It may have - but IIRC, after I upgraded to a 80GB HDD I saw the same error message until I re-built the DB several times. It then just disappeared...
